Mr.SoapPowder
- Oct 12, 2011
Well i stumbled accross this website last night looking for a nice forum about w/c, and decided i want to redo my loops.
when i did this setup the first time i was still a bit green on all the aspects so i had a friend come and help me.
Here is everything i got in my computer and ill explain my loops as well.
Rig:
Intel Core i7 930 running at 4.2ghz
EVGA X58 Classified LE E759 BIOS
3x2gig OCZ Golds 8/8/8/24 @ 1600MHZ(Stock)
EVGA Nvidia GeForce GTX 480 at 820/1640/1903
2X OCZ Vertex 30GB SSD Raid 0
300GB 10,000RPM Velociraptor
Corsair TX750 750watt PSU
Lian Li 343B Case
I have 2 seperate loops in the watercooling setup
Loop 1:
Laing D5 pump with koolance block -> Koolance CPU 350AT block -> Koolance NB/SB block for 58 Classified -> Bits Power Voltreg for X58 Classified -> Magiccool 1080 9x120mm Radiator -> Bitspower res -> Pump
Loop 2:
another D5 Pump -> Koolance GTX 480 block -> Koolance 3x120 Radiator-> Bitspower Res->Pump.
i have been reading alot into the forums and have noticed that most of this is really overkill for the system. So i have been thinking about it throughout the night and i want to try and get a multipump system going and combine the loops, but i have no idea on how to setup 2pumps in 1 line. i came up with an idea but i need alot of opinions on if it will work properly or not. i will lay it out.
Res - Split to pumps - Each pump hit a rad- 1 rad split 1 tube going to cpu other going to NB/SB Volt reg - other rad going to gpu and combine again to hit the res
i know it seems overkill and un needed but those are all the parts i have right now including an extra koolance 3x120 rad sitting around.
so thats what i have so far im still thinking of different ways to run the loop. Any pointers are greatly appreciated.
Rig:
Lian Li 343B Case
Loop 1:
Loop 2:
