morpheus50
- Nov 14, 2016
I never used this i think. How do you load up century bombers with infantry?
Haven't played RA3, but if it's at all like the previous games, you just select the infantry and tell them to move to the other unit. If they can get on, the cursor will change to a green arrow before you give the command.I never used this i think. How do you load up century bombers with infantry?
Hmm i think i tried to tell them to move to the century bomber and no green cursor. Yeah i have n't played in years so i forgot or never tried.Haven't played RA3, but if it's at all like the previous games, you just select the infantry and tell them to move to the other unit. If they can get on, the cursor will change to a green arrow before you give the command.
