Wasn't sure which section to post this, but just swapped motherboards to evga 750i ftw, reformatted and reinstalled vista 64-bit on my raid 0 drives, and since then have experienced multiple boot sector failures. Probably 3 since I installed the OS last night. All have been around nforce driver updates, but was worried that one of my drives may be failing. any suggestions?
Edit: Solved. Swapping SATA channels between my 2 raided drives and my backup assigned the RAIDed drives as C:\. Now no more boot issues.
Edit 2: To go into more detail, it appears as though my mobo assigns (and reassigns upon boot) the drive letters, so using diskpart in vista recovery disk to reassign drive letters is useless. However, changing the boot priority of the drives in the bios does seem to work. Changing the hard drive I wanted to boot from to the LOWER priority (below the other on the list) would assign it as C, and assign the others up from there. Weird, don't know if it's a BIOS bug or not.
