Recommendation for a mATX motherboard with...
Staples
The BIOS option to turn off all errors on post, even keyboard. I need a micro ATX board that supports an LGA775 socket (I use a Celeron D) and uses DDR SDRAM. Integrated video is not important but either way is fine. This won't be a performance computer so the cheaper, the better.
I bought a Celeron system and was using an Intel D101GGC motherboard . This is a microATX board based on an ATI Radeon 200 Xpress chipset. I am not sure if it was the chipset or what but the BIOS did not have an option to turn off post errors. I was using this as a server without a keyboard, monitor or anything and restarting it became a real pain in the ass.
Yesterday I tried to flash the BIOS to see if the newest BIOS added the options. I used a linux dos boot CD since my floppy was not working. I used another CD in which I had burned the new BIOS to. Everything looked to have gone right but when I restarted, the computer was toast. Nothing but long beeps. Guess I won't be using that combo again. I will be using a floppy and MS DOS.
The Asus P5RD1-VM is mATX, uses ATI 200 and DDR.
http://www.asus.com/products4.aspx?l1=3&l2=11&l3=179&model=770&modelmenu=1
I didn't get a chance to download the manual and check but any ASUS Ihave ever had has the option in the bios you want.
Be sure you get the right one the P5RD1-VM uses DDR but the P5RD2-VM uses DDR2.
One other thing I can't remember is if the ULI SB has problem with Linux or not, you'll have to check on that.
