recommend me a printer
leeroy
i was looking at the hp laser printer 1015 when it was £150 but now its £200 so cant afford it.
checking on ebuyer and dabs i quite like the hp psc 1110 all in one with scanner, printer , copier. does anyone have it? i want a review; from reading the reviews it says its good but quite noisy. are the cartrdges no56 and no57? im looking in that price range. £65
thank you.
WOOT I JUST ORDERED THE HP PSC 1355.
INKJET.
SCANNER
PRINTER
COPIER IN ONE
WITH DIGI CAM READER
£99 + £10 P+P FROM PCWORLD.CO.UK - WHATCHA THINK GUYS?
http://www.pcworld.co.uk/martprd/st...98&category_oid=-9858&fm=null&sm=null&tm=null
i have a psc they suck so much. laser was the way to go but i must say if u like spending lots of money on ink the psc does print good color and black and white though.
ur jokinG!? :O why do u say that?
i read up that black and white and colour tri cartridges costs about £15 each
part no 56 and 57? whcih gives rouglhy 400 pages of print pages?
well i don't know how it works on yours but my printer has a seperate b/w then a color, so if the color goes out u can still use b.w i guess i shouldn't say it sucks printing which it doesn't but if your going to use the copier it does not copy like a laser printer. EVERYTHING IS IN COLOR meaning if u have a yellow paper that is printing it'll copy the yellow page to the exact which burns ink like crazy. my mom uses it alot to copy music and sometimes the pages are green so itll print it green with the rest of the text. i'm thinking of getting a laser copier so the copy's actually print in monochrome. and everytime i drop some ink into it costs about 25 a cartridge or 50 bucks because we usually get the black saverpack which doesn't have color so u need the color one too which is another 50 plus they only give u starter packs of ink with new printers so your going to have to spend some money early on getting ink. all in all it still does print well. i just hate the copy aspect which makes it more expensive anyway. cheers
oic so u tryna say the qualitys ok but suck as in the way the cartrdges work?
:O NOOOOOOOO WAYYYYYYYYYYY, OMG THATS POOO. i guess i will have to scan it as b&w or scan it into software then make the background as white before printing it
yea this hp psc 1355 uses 2 cartrdges as it says, one black and one colour.
thank u for that info. i didnt know that.
if i heard correctly, doesnt HP base that number on 3% page coverage of text? (which is roughly half a page of double spaced text... i think)
is the the correct qoute if i can recall is 15% coverage to produce 415 pages.
