recommend me a dual socket 771
TeleFragger
ok so i am new to building one of these...
but trying to build it on a budget...
i have the cpus
2 x L5240 xeon 3.0
also they say these take ddr2 667 memory...
is that the same as pc2 5300u? i have 4 x 1gb of those.....
if that is the case..
I need a
mobo, 2 heatsinks and most likely a power supply....
what do you recommend on a good but non expensive mobo?
machine is to be built for windows home server and a few vm sessions....
was lookin at this one
http://www.newegg.com/Product/Product.aspx?Item=N82E16813182158
or openbox for $172.... save a few bucks and just dont get sata cables and backing plate..
http://www.newegg.com/Product/Product.aspx?Item=N82E16813182158R
now that i think about it... the xw8200 hp will do me fine... im just gonna ebay up the L5240 771 chips....
It depends on how many PCIe slots and of what bandwidth you need. I've got the X7DCL-i, which has 3x PCIe 8x slots, and it's great.
well i was just going to run it as a server.. dont touch kinda deal..
windows home server..... sun virtualbox running windows 7 for home automation..
that is it....
well dcpromo it... and dhcp, dns, etc...
that is it....
If you're not going to use a whole lot with it then it doesn't matter much. I was originally looking at that board because it's mATX so I could fit it in a range of cases, but I ended up getting a great deal on the -i. Either one will work.
I'd prefer something with a Intel 5400 series chipset. However that's considerably more expensive than those boards you listed.
