recommend me 20" widescreen ~$250
Zoogle
I've looked around but can't seem to find many decent 20" widescreen panels around that price range. There are lots of conflicting reviews so I'd really just like to hear some of your personal opinions. Also, please don't give a reason for a particular monitor being better because it has "X ms better response time and XXXX:1 contrast ratio." Response time ratings are usually BS, as are contrast ratios.
I'll be primarily using the monitor for work, browsing, watching TV, and occasional gaming so color reproduction, contrast, and reliability are more important than blazing fast response times. Thx for the suggestions.
There's not much to choose from in that range as you know. If I had to pick one of the displays in that category I would get the Acer just because I heard good things about it:
http://www.newegg.com/Product/Product.asp?Item=N82E16824009085
That and a Samsung are all I could think off. Personally I would try to get another hundred into it since your just going to get souped-up TN panels at 200 -250. They arent best for colors and watching TV at distance or angle.
