Aggravation
- Mar 2, 2006
Which setting would you pick for best performance in gaming and creating DVD's from digital video camera files?
In both cases using a AMD X2 4400+ and 2 gig of OCZ DDR400 RAM....
1) (stock settings) 200 mhz CPU clock x 11 multiplier, 1000mhz HTF, 200mhz memory clock RAM at 2,3,2,5 1T
resulting in CPU running at 2.2 ghz
Or...
2) 228mhz CPU clock x 11 multiplier, 800mhz HTF, 166mhz memory clock RAM at 3,5,4,7 1T
resulting in CPU running at 2.5 ghz *but* causing memory to be underclocked at 179mhz
Basically which is better, higher CPU frequency but with lower RAM frequency or both at stock and lose the 300mhz overclock on the CPU
Or...
