Reaching for 1000FSB
DBRASCO
I just swapped out a ga-8knxp for an abit IC-7Max3.... Everything went well... my prblem is this! setting the FSB to 250 w/vcore at 1.65, dimm@ 2.8, and agp set@ 1.6. I can load memtest and run at 250 FSB for hours w/no errors 1:1, but the sytem will not boot into windows...
Going up on dimm voltage wont help xms4000pro....3-8-4-4. and the sytem wont boot at all 5:4....
Any suggestions? I didn't know how far I good go on the Vcore. I'm running EXOS cooling and temps are at 42c full load...
Thanks , Brasco
set
Vcore to 1.6250
VDimm to 2.8
NBSTRAP to "By CPU"
Manually set the ram timings to 3-4-4-8
and then give it a go...
those are the current settings in the bios. and I have been as high as 1.65...
Everything runs fine during memtest. I just can't get it to boot into windows...
anymore help? How high can I safely go on Vcore? w/out S.N.D.S. happening....
