Capt.Frito
- Mar 18, 2013
Does anyone know the exact steps for doing a raid set delete/re-create with no-init option using cli64 ? I can't see the option listed in either the rsf create (or in the vsf create).
For the record, I have a "failed" RAID5 which happened when I unplugged the array without 'offlining' it first. The disks have not been changed in their physical order. So hopefully this will work. There are 12 disks and all were/need to become members of the recreated array.
These are WDC WD6000BLHX-01V7BV0 SATA disks in a SansDigital AS224X JBOD (built-in SAS expander). the card is an Areca 1882 that was private-labeled by SansDigital. (I've included the tail of the log, it probably won't be very useful since this isn't the Areca card used to create the raid volume, nor is it the one that was involved with the reckless unplug event that cause the problem)
Here are the details:
TIA
Code:
The System Information
Main Processor : 800MHz
CPU ICache Size : 32KB
CPU DCache Size : 32KB
CPU SCache Size : 1024KB
System Memory : 1024MB/1333MHz/ECC
Firmware Version : V1.51 2013-01-23
BOOT ROM Version : V1.51 2013-01-23
Serial Number : Y143CADDAR200112
Controller Name : Sans Dig
Current IP Address : 172.16.3.168
GuiErrMsg<0x00>: Success.
RaidSet Information
# Name Disks TotalCap FreeCap MinDiskCap State
1 MB1-RAID 12 7200.0GB 0.0GB 600.0GB Failed
VolumeSet Information
# Name Raid Name Level Capacity Ch/Id/Lun State
1 IRAID24 MB1-RAID Raid5 6600.0GB 00/00/00 Failed
Physical Drive Information
# Enc# Slot# ModelName Capacity Usage
1 01 Slot#1 N.A. 0.0GB N.A.
2 01 Slot#2 N.A. 0.0GB N.A.
3 01 Slot#3 N.A. 0.0GB N.A.
4 01 Slot#4 N.A. 0.0GB N.A.
5 01 Slot#5 N.A. 0.0GB N.A.
6 01 Slot#6 N.A. 0.0GB N.A.
7 01 Slot#7 N.A. 0.0GB N.A.
8 01 Slot#8 N.A. 0.0GB N.A.
9 02 SLOT 01 N.A. 0.0GB N.A.
10 02 SLOT 02 N.A. 0.0GB N.A.
11 02 SLOT 03 N.A. 0.0GB N.A.
12 02 SLOT 04 N.A. 0.0GB N.A.
13 02 SLOT 05 N.A. 0.0GB N.A.
14 02 SLOT 06 N.A. 0.0GB N.A.
15 02 SLOT 07 N.A. 0.0GB N.A.
16 02 SLOT 08 N.A. 0.0GB N.A.
17 02 SLOT 09 N.A. 0.0GB N.A.
18 02 SLOT 10 N.A. 0.0GB N.A.
19 02 SLOT 11 N.A. 0.0GB N.A.
20 02 SLOT 12 N.A. 0.0GB N.A.
21 02 SLOT 13 WDC WD6000BLHX-01V7BV0 600.1GB MB1-RAID
22 02 SLOT 14 WDC WD6000BLHX-01V7BV0 600.1GB MB1-RAID
23 02 SLOT 15 WDC WD6000BLHX-01V7BV0 600.1GB MB1-RAID
24 02 SLOT 16 WDC WD6000BLHX-01V7BV0 600.1GB MB1-RAID
25 02 SLOT 17 WDC WD6000BLHX-01V7BV0 600.1GB MB1-RAID
26 02 SLOT 18 WDC WD6000BLHX-01V7BV0 600.1GB MB1-RAID
27 02 SLOT 19 WDC WD6000BLHX-01V7BV0 600.1GB MB1-RAID
28 02 SLOT 20 WDC WD6000BLHX-01V7BV0 600.1GB MB1-RAID
29 02 SLOT 21 WDC WD6000BLHX-01V7BV0 600.1GB MB1-RAID
30 02 SLOT 22 WDC WD6000BLHX-01V7BV0 600.1GB MB1-RAID
31 02 SLOT 23 WDC WD6000BLHX-01V7BV0 600.1GB MB1-RAID
32 02 SLOT 24 WDC WD6000BLHX-01V7BV0 600.1GB MB1-RAID
Physical Hardware Information
The Hardware Monitor Information
[Controller H/W Monitor]
CPU Temperature : 46 C
Controller Temp. : 37 C
CPU Fan : 5818 RPM
12V : 12.038 V
5V : 5.026 V
3.3V : 3.344 V
IO Voltage +1.8V : 1.840 V
DDR3 +1.5V : 1.520 V
CPU VCore +1.0V : 1.024 V
Analog +1.0V : 1.040 V
DDR3 +0.75V : 0.752 V
Battery Status : Not Installed
[Enclosure#1 : ARECA SAS RAID AdapterV1.0]
[Enclosure#2 : AS224X sans Dig-.01.13.0113]
1V : 1.030 V
5V : 5.060 V
3.3V : 3.320 V
12V : 11.930 V
Fan 01 : 4010 RPM
Fan 02 : 3970 RPM
PowerSupply01 : OK
PowerSupply02 : OK
ENC. Temp : 28 C
Chip Temp : 33 C
Slot01 Temp : 34 C
Slot02 Temp : 35 C
Slot03 Temp : 35 C
Slot04 Temp : 35 C
Slot05 Temp : 35 C
Slot06 Temp : 35 C
Slot07 Temp : 34 C
Slot08 Temp : 34 C
Slot09 Temp : 35 C
Slot10 Temp : 34 C
Slot11 Temp : 34 C
Slot12 Temp : 34 C
Slot13 Temp : 34 C
Slot14 Temp : 33 C
Slot15 Temp : 33 C
Slot16 Temp : 34 C
Slot17 Temp : 34 C
Slot18 Temp : 34 C
Slot19 Temp : 35 C
Slot20 Temp : 35 C
Slot21 Temp : 35 C
Slot22 Temp : 35 C
Slot23 Temp : 35 C
Slot24 Temp : 34 C
Event Information
Date-Time Device Event Type Elapsed Time Errors
2013-05-04 15:06:10 SW API Interface API Log In
2013-05-04 14:59:21 SW API Interface API Log In
2013-05-04 14:55:41 H/W MONITOR Raid Powered On
2013-05-04 14:59:29 SW API Interface API Log In
2013-05-04 14:57:48 SW API Interface API Log In
2013-05-04 14:57:23 SW API Interface API Log In
2013-05-04 14:55:39 SW API Interface API Log In
2013-05-04 14:47:45 SW API Interface API Log In
2013-05-04 14:03:57 H/W MONITOR Raid Powered On
2013-05-04 13:49:01 H/W MONITOR Raid Powered On
2013-05-04 13:46:34 RS232 Terminal VT100 Log In
2013-05-04 13:45:56 H/W MONITOR Raid Powered On
2013-05-04 03:53:34 Enc#2 Disk-08 Device Removed
2013-05-04 02:46:03 Enc#2 Disk-08 Device Removed
2013-05-04 02:38:12 SW API Interface API Log In
2013-05-04 02:35:16 Incomplete RAID Discovered
2013-05-04 02:35:16 H/W MONITOR Raid Powered On
2013-05-04 02:35:21 SW API Interface API Log In
2013-05-04 01:17:06 H/W MONITOR Raid Powered On
2013-05-03 15:08:29 H/W MONITOR Raid Powered On
2013-05-03 15:03:16 H/W MONITOR Raid Powered On
2013-05-02 00:29:59 H/W MONITOR Raid Powered On
2013-04-30 19:39:50 H/W MONITOR Raid Powered On
2013-04-30 18:55:53 H/W MONITOR Raid Powered On
2013-04-30 18:39:27 H/W MONITOR Raid Powered On
2013-04-30 18:17:29 RS232 Terminal VT100 Log In
2013-04-30 18:16:48 H/W MONITOR Raid Powered On
2013-04-30 17:25:47 H/W MONITOR Raid Powered On
2013-04-30 17:20:49 H/W MONITOR Raid Powered On
2013-04-30 15:17:57 H/W MONITOR Raid Powered On
2013-04-30 15:10:56 H/W MONITOR Raid Powered On
2013-04-30 14:40:39 H/W MONITOR Raid Powered On
2013-04-30 05:11:20 H/W MONITOR Raid Powered On
2013-04-30 05:05:40 H/W MONITOR Raid Powered On
2013-04-30 04:56:25 H/W MONITOR Raid Powered On
2013-04-30 04:49:23 H/W MONITOR Raid Powered On
2013-04-30 01:58:14 H/W MONITOR Raid Powered On
2013-04-30 01:35:25 H/W MONITOR Raid Powered On
2013-04-30 01:32:08 H/W MONITOR Raid Powered On
2013-04-30 01:22:09 H/W MONITOR Raid Powered On
2013-04-30 01:16:26 H/W MONITOR Raid Powered On
2013-03-22 20:23:24 MB1-RAID Offlined
2013-03-22 20:22:55 172.016.003.219 HTTP Log In
2013-03-21 16:21:53 Enc#2 Disk-07 Device Inserted
2013-03-21 16:21:53 Enc#2 Disk-08 Device Inserted
2013-03-21 16:21:53 Enc#2 Disk-06 Device Inserted
2013-03-21 16:21:53 Enc#2 Disk-05 Device Inserted
2013-03-21 16:21:53 Enc#2 Disk-04 Device Inserted
2013-03-21 16:21:53 Enc#2 Disk-03 Device Inserted
2013-03-21 16:21:53 Enc#2 Disk-02 Device Inserted
2013-03-21 16:21:53 Enc#2 Disk-01 Device Inserted
2013-03-21 16:21:53 Enclosure#2 Added
2013-03-21 16:03:44 Enclosure#2 Removed
2013-03-21 16:03:44 Enc#2 SES2Device Device Removed
2013-03-21 16:03:44 Enc#2 Disk-08 Device Removed
2013-03-21 16:03:43 Enc#2 Disk-07 Device Removed
2013-03-21 16:03:43 Enc#2 Disk-06 Device Removed
2013-03-21 16:03:43 Enc#2 Disk-05 Device Removed
2013-03-21 16:03:42 Enc#2 Disk-04 Device Removed
2013-03-21 16:03:42 Enc#2 Disk-03 Device Removed
2013-03-21 16:03:42 Enc#2 Disk-02 Device Removed
2013-03-21 16:03:42 Enc#2 Disk-01 Device Removed
TIA
