Rate My Rig (please)
uluvbs
COOLER MASTER Centurion Micro ATX 541 RC-541-SKR1 Black
Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive
MSI K9N6PGM-F Socket AM2 NVIDIA GeForce 6100 Micro ATX AMD Motherboard
DIAMOND XtremeSound XS71DDL 7.1 Channels PCI Interface Sound Card - Retail
2 x Kingston 1GB 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Desktop Memory Model
AMD Athlon 64 X2 3800+(65W) Windsor 2.0GHz Socket AM2 Processor Model
Windows Vista 32-Bit Home Premium for System Builders Single Pack DVD
EVGA 256-P2-N541-T2 GeForce 7600GS 256MB GDDR2 PCI Express x16 Video Card
NEC 18X DVD±R DVD Burner With 12X DVD-RAM Write Black E-IDE / ATAPI
$753 total from NewEgg.
Since I'm not planning on gaming much, is this system overkill?
(It will be used mainly for HDTV home theater, Web surfing, and MS Office)
Thank you.
check out some reviews of that case, I was going to buy it but since the mobo is inverted the PSU cables have to route over the GPU/soundcard, it was a deal killer for me....I liked that case to.
doesn't look overkill to me, especially since it sounds like you will game once in a while.
For that price I'd go for a Core2Duo. They also run cooler and outperform their amd counterparts.
