Rate my ghetto build
rotteneggz
This isnt an upgrade, its more like a replacent from my current rig wich is going to the office for better use.
(Canadaian prices)
ASRock 775DUAL-VSTA 80.92$
Intel Pentium D 820 117.98$
Coolermaster Elite RC-330 39$
Western Digital 160gb 68$
LG DVDR 36$
Corsair Value Select PC2-5300 1GB 93$
Fortron Sparkle 400W ps 45$
After taxes, shipping, and insurance it came up to 581$
Since the only games i play are quake 2-3 and cs 1.6 i didnt really see the need in buying a new vid card so ill be using my old geforce 6800 vanilla in the new rig.
Current rig:
AMD Athlon xp 2400+
Abit nf7-s
Geforce 6800
512mb Ram
120GB hd
How big of a difference will it be going from the old rig to the newer?
if you're only playing q2-3 and 1.6, you aren't going to notice much of a performance difference. To be honest if those are the games you play I would stick with your current rig until the next entire rebuild.
I think the old PC is perfect for those games... but you'd get a boost in all other tasks. You'll get higher FPS probably in the games but it probably wouldn't be that noticeable.
I'd pass on the FSP, try the XClio 450BL or Goodpower 500w, they're in the same pricerange
I'd up the ram to DDR2 800 just in case.. The price difference is like a big mac.
how much are pentium d 915s in canada? on newegg its less than $20 more than the 820.
It was about 15-20$ more. I gave it some thought in buying the 915 over the 820 but since i was on a TIGHT budget and the 820 is more then enough for those games i decided to save the extra 20$. Like i said before, this isnt an upgrade so i can play games with better fps or newer games, my old pc is more then enough for q2-3 and cs 1.6, but i needed a pc for the office so instead of building a new pc for the office i get the new one and the office gets the old one :D
