Raspberry Pis, network equipment, CPU, RAM
Lebowski
1x Raspberry Pi 4 2GB with POE hat and USB-C power cord $80
1x Raspberry Pi 4 4GB with POE hat and USB-C power cord $90
1x Raspberry Pi 3b bare $35
1x Raspberry pi 3b in FLIRC case $40
1 Intel Core i3 13100F with stock cooler - used for maybe 10 minutes to test something $80
TP-link RE300 AC1200 range extender $20
TP-Link RE505x AX1500 Range Extender $20
Zyxel NWA50AX Wifi 6 AP (power cable or POE) Includes ceiling mount $40
TP-Link TL-SG108E 8-port smart gigabit switch $20
YuanLey switch 5x2.5Gb rj45 ports an 2 SFP+ 10Gb ports $25
TP-Link TL-605 SafeStream Gigabit Multiwan VPN Router $30
Mokerlink 8-port 2.5 GB switch $35
Noctua NH-L9a AM4 cooler/fan $25
Byski 150mm Reservoir/d5 pump combo $100
2x 2.5GB PCI-E NIC (realtek chipset) 1 has a full height pci-e slot plate, the other has a cut down plate to fit a half height slot. $10 each
USB-C hub/dock link $20
USB-C hub/dock with 1GB ethernet link $20
4x8GB DDR3 1600 mhz Corsair Vengeance RAM $50 a pair.
Are either of these managed?
Does the Mokerlink have an SFP+ port on it? I can't find a corresponding switch on their website without one.
I'm inclined to take one of them, preferably the Mokerlink if it has a SFP+ port on it.
