Random reboot help request
mtbaird
im running my 2.4@3.4 with stock voltages
overheating isnt an issue
all im doing is CS and it messed up
what do yall think i should do? to computer just reboots, no errors or anything like that...
im thinking i need to up the voltages? maybe? if so what to?
Fortron FSP350
i ran it incredibly stable at the same settings for 9 hours once
Me thinks your PSU is the root of your problem - but I can't say for sure...
im going to do all these things yall are saying only if it happens again
i gotta make sure its not a fluke thing ya know
ram voltages shold be fine, its running at 190x2 instead of 200x2, due to 3:2 ratio
and i really hope my PSU isnt the problem, i dont see how it could be Fortron is an excellent brand and all my voltages are rock solid
I hit that problem, check ram timings and voltage. Look for bios update, you may have an unsupported
whats your specs
2.4C @ 3.4
Soundblaster Audigy
Radeon 9800 non-pro (saphire)
Abit IS7-E Bios 15
80 gig WD SE
(2x256) 512 total GEIL Dual Channel Golden Dragon ram, 2-6-3-3
ram is running at 380mhz instead of 400mhz due to 3:2 ratio for OC
well so far it hasnt happened anymore today.
