need help, upon building new system on existing watercooling solution i found out my swiftech fill bleed kit doesnt fit in my case anymore, so therefore i need something to detach it when im done bleeding the system. So I need some 1/2" cutoff valves. Basically what im going to do is have a normal setup, and then have a T connector that runs a normal pattern through the system and the 3rd connector to the fill bleed kit. Id like that third connector to be able to shutoff, so basically im looking for a cutoff valve 1/2" to 1/2" ID. Anyone know where i can get one, i havent found any at home depot, loews, nor ace hardware. Need help. If anyone knows where to get 2 of them, either a T shaped valve with a cut off switch to one of the connectors or just a straight through cutoff switch. Thanks.
