Hi all,
I'm experiencing a bit of a problem.
I swapped out my hd 4890 for my new gtx 660 sc and now my computer won't start.
I used to have a water cooled system but the pump stopped working so the unit was useless, I purchased a freezer pro 13 and everything has been fine... this was months ago.
While I was swapping out my card today I decided to remove (rip out) the useless pump, unfortunately I got some fluid, only a small amount of non conducting PC ICE, on the board itself and when I tried to power it all back up my lcd poster kept flashing cpu init and wouldn't power up. very worried I hung a hairdryer over it for about 20 minutes then plugged it back in.. now the poster says welcome, as it should, and the motherboard is lit up as normal, however when I press the power button it doesn't do anything at all, neither does the onboard start button.
As stated the board looks fine, lit up in all the right places, my poster reports properly there just doesn't seem to be a signal sent to tell it to powerup.
It's all a pain in the butt, the gpu is brand new today.
Does anyone have any suggestions or am I as screwed as I think I am?.. if I am screwed and need a new mobo.. if I manage to get another rampage extreme 1 will I be able to keep my data.. or will I have to reinstall my OS also?
Please someone have some good news for me. (pleading smile)
