ram timings help
xcite
I have 1gb 3500eb how do i change the ram timings? I tried to google some info and all i got was some tomshardware bullshit. Could someone tell me how to set or change my ram timings? I dont know if you can change them in windows or the bios. Some one told me to run them at at 3-2-2-10. This dosnt make sence to me, in my ram bios page says:
Max memclock(mhz) [auto]
1T/2T memory timing [2T]
CAS # latency [2.5]
RAS # CAS# delay [4]
Min RAS # active time [5]
Row precharge time [6]
what should all this stuff be set at. my max overclock stable has been 2.3. Any help ideas links to websites with info becasue in stumped
*Gasp* A good question!
Set 1T/2T memory timing to 1T
CAS to 3.0
RAS to 2
Min RAS to 2
and Row precharge time to 10
Give some more voltage to the RAM to keep it stable and maybe even get a few more MHz out of it. Also incease the vcore so you can overclock the CPU more.
there should be a spot in bios that lets you change it to manual/expert. after you do that it will let you change it to whatever you want.
CAS # latency [2.5]
You are going to have alot more problems than just ram timing if you don't send me the item that I bought from you!!
:mad:
http://hardforum.com/showthread.php?t=800333
