Blueduck577
- May 11, 2007
Hi guys,
I installed 4GB of RAM in my Asus P5B deluxe, but Windows Vista x64 only shows it at 3006MB. The Asus BIOS only shows it at 3008MB. Where did the other thousand MB go? I have tried putting in every possible combination of RAM into every combination of the 4 DIMM slots. Each piece of RAM works. Each slot works. It's just that when I have three pieces of RAM in, the BIOS would say I have 3008MB. But when I put in the fourth, I still have only 3008MB, the BIOS says. Does anyone know why?
ALSO: What are good temps? I am idling at 29C for CPU and 32C for Motherboard, and that's when I have the fans on low.
When I'm gaming, I have the fans set on high, and I have around 35C for CPU and 37C for Motherboard. I would like to put the fans on low, though, because everything is so loud on high or medium. Should I? What temps should I make sure to stay under?
I'm using Antec P180B
C2D E6600 (Not OC'd)
Asus P5B Deluxe Motherboard
4x1GB Corsair XMS2 2GB 800 (PC2 6400)
Tuniq 120 Cooler
evga 8800GTX
etc
Rest of parts can be found here.
http://www.hardforum.com/showthread.php?t=1190128
As always, thanks for help in advance.
Tuniq 120 Cooler
evga 8800GTX
etc
