Nazo
- Apr 2, 2002
So I have a headphone amp I use with my computer -- a CMoy using an AD8620 OPAMP (this particular combination sounds incredible as if it were far better than a CMoy IMO and seems to suit my headphones very well.) I've been using 8xAAAs to get the voltage high enough, but I just recently bought a super-cheap battery + charger for my phone (Samsung Galaxy S3, so the battery is fairly beefy for a phone and while this one is a cheap made in China battery that probably delivers far less than in advertises -- especially considering how little it weighs) and it turns out that I got a better deal on Amazon for a two pack of a higher quality battery with a better charger...
I couldn't help but to think that it might well be a LOT more convenient to just use a single quality rechargeable battery from a phone that's this popular (it probably goes without saying that they'll be making batteries for this thing for a very long time indeed) and maybe possibly even grab another of the Amazon deal with the two higher quality batteries later on if this works out. It would probably be pretty easy to adapt one of the chargers to use a switch to provide power or charge depending on where it's set and just essentially use it as the battery holder as well, so it might theoretically work.
So I've heard that it's possible to raise voltage. I do of course realize this isn't 100% efficient (and that more current is required to compensate as well) and even if the use time is worse than the AAAs (which was I think as many as three or four months or so probably -- I lost track -- so even if I assume 1/3rd the time it's still very good) but this is actually a LOT more convenient even at the worst if it works. Does anyone know the specifics of how to actually do this? Could I raise a battery that's "3.7V" (though it seems they charge as high as 4.3 these days apparently) all the way up to 10+V? And, if I could, given the nature of the project (a headphone amp) would it produce any noise that could be picked up by such sensitive circuits? It probably doesn't take much at all really...
