Raid recovery question
Ethereal
Pretty sure I'm screwed, but I figured I'd throw this out there. A while back I was having issues with some drives I had in Raid 0 (2 160 gig IDE drives on a Promise Fasttrack TX2). Went through and rebuilt the array and got the drives up so I could see them (amazingly the data stayed on them), but I couldn't boot into the OS. Cleaned another drive off and popped in a windows CD to install the OS on the new drive. Well, the new drive was 320, same as my raid and I loaded the promise drivers and tried to do a recovery, that failed and I chose to install windows, but somehow chose the raid array and started formatting. Got to 3% before I said crap and stopped the format. Just curious if there's anything that can be done to recover any of the data. I'm thinking since the MBR's were probably wiped I'm screwed, but wanted to make sure. Not important enough to spend thousands on physical recovery, but some things that are making my fiance upset since she can't get to them are worth me at least asking. Thanks in advance.
hmm try something like active partition recovery, it might be able to rebuild your old partition table information.
