raid possible for same model, different revision?
ArChSeN
i just bought another WD 160G sata hard disk to make a raid array..
but later i realized that my older one was simply called WD Caviar, and the new called WD Caviar SE. Its both SATA, same capacity, same power consumption.. but im a little worried.
will these two drives work seamlessly as a any raid array?
The full model names are:
older : WD1600JD-75HBB0 - WD Caviar
newer : WD1600JD-22HBB0 - WD Caviar SE
thanks a bunch!
Raid arrays don't need identical drives. The overall performance though, will be limited to the lesser of the two.
