Raid Help on a Clean Install
[BB] Rick James said:
Is there a way to load the Raid drivers if you don't have a floppy drive?
You can slipstream them into a new install cd. Same with SP-2.
Luck
This is the spot I'm getting confused at or not doing properly.
So it says.
Step Two - Copy Drivers
Add your SATA drivers to the appropriate XP Distribution Directory.
In this example the directory $OEM$\$1\DRIVERS\006\SI3112 is used. Directory Listing
Directory of E:\XPCD\$OEM$\$1\DRIVERS\006\SI3112
23.09.2003 11:05 10,236 si3112.cat
16.09.2003 10:43 11,094 SI3112.inf
04.09.2003 12:45 55,144 Si3112.mpd
04.09.2003 12:45 55,144 Si3112.sys
30.04.2003 08:35 20,560 SiiSupp.vxd
31.07.2003 09:01 69,120 SilSupp.cpl
09.06.2003 17:56 10,112 SiWinAcc.sys
7 File(s) 231,410 bytes
Now my drivers I'm using are different then the drivers they are slipstreaming. So where do I find this info to add? Isn't this information for the driver set they are trying to add?
^^^ Where do I get that info for my driver?
