Raid 10 question
Nescoupe
I spoke with ASUS USA and asked some questions regarding setting up my current build but I am kind of confused. I am building a new computer for photo and video editing and am using the following parts.
ASUS ROG MAXIMUS VIII EXTREME/ASSEMBLY LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 USB 3.0 Extended ATX Motherboard
SAMSUNG 850 EVO M.2 500GB SSD SATA III Internal Solid State Drive MZN5E500BW
4 WD Blue 1TB Internal SSD Solid State Drive SATA 6Gb/s 2.5 Inch WDS100T1B0A
Windows 10 Pro 64bit
They told me that I could boot from the M2 drive and have the RAID 10 and told me that I would have to create a RAID floppy disk but according to the manual it says that you have to create the disk if you are installing the O/S on the RAID which I don't intend on doing I am going to use the RAID strictly for storage. Would someone please enlighten me!
Cheers
you don't need a raid floppy unless you are installing the os to that.
you're not so you don't need it.
install the os to the m.2 ssd and then add the raid array afterwards.
leave the drives unplugged until you are done installing windows.
also you don't even have a floppy header on your board... i dont even....
The way I did it was to install windows and finish the boot drive m.2. Then connect up all my RAID drives and boot into windows and set them up individually and go into Intel Rapid Storage Tech control panel and create the RAID array from there.
EDIT: What he said :-D
Thanks guys for all the help, I am really excited about this build. I am using this rig for my photography business but I'm sure that I will be tempted to tweek it and see what she will do, here is a list of what I have:
1 Phanteks Enthoo Luxe Series PH-ES614L_BK Black Aluminum / Steel ATX Full Tower Computer Case
1 ASUS ROG MAXIMUS VIII EXTREME/ASSEMBLY LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 USB 3.0 Extended ATX Intel Motherboard
2 ASUS ROG GeForce GTX 1070 STRIX-GTX1070-O8G-GAMING 8GB 256-Bit GDDR5 PCI Express 3.0 HDCP Ready Video Card
1 CORSAIR RMi Series RM1000i 1000W 80 PLUS GOLD Haswell Ready Full Modular ATX12V & EPS12V SLI and Crossfire Ready Power Supply with C-Link Monitoring and Control
1 Intel Core i7-6700K Skylake Quad-Core 4.0 GHz LGA 1151 91W BX80662I76700K Desktop Processor Intel HD Graphics 530
1 G.SKILL Ripjaws V Series 64GB (4 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Intel Z170 Platform Desktop Memory Model F4-3200C16Q-64GVK
4 WD Blue 1TB Internal SSD Solid State Drive - SATA 6Gb/s 2.5 Inch - WDS100T1B0A
1 SAMSUNG 850 EVO M.2 500GB SSD SATA III Internal Solid State Drive MZ-N5E500BW with 2.5" SSD plastic case
Form Factor: M.2 Capacity: 500GB
2 Corsair ML120 PRO LED CO-9050042-WW 120mm 120mm Premium Magnetic Levitation PWM Fan
1 ASUS ROG Front Base Dual-Bay Gaming Panel 4 inch LCD
1 ASUS Black Blu-ray Drive SATA
1 Windows 10 Pro 64-bit
3 Corsair ML140 PRO LED CO-9050047-WW 140mm 140mm Premium Magnetic Levitation PWM Fan
1 ASUS ROG Enthusiast 2Way SLI Bridge ROG Enthusiast 2-Way SLI
1 Corsair Hydro Series H115i Extreme Performance Liquid CPU Cooler, 280mm CW-9060027-WW
I also have a 10 by 6 graphics tablet by Wacom that I am going to use once I am finished modding the case with the Sith Empire emblem in blood red and my company logo...I'm a hopeless Star Wars fan and yes powder coated chassis and braided cables.
Cheers and Thanks
