Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Hey guys.......by any chance do they make a pci type card that can hook up to an antenna and recieve local radio staions then put it out the computer speakers?
I listen to shoutcast all the time, but sometimes I do to wish i had local FM radio on the pc so i can listen to the local talk morning shows........
I mean yeah i can get an alarm clock or a little radio but those usually sound like crap. The speakers on my pc here at work are much better than those cheap radios.
Found some here under 40 bucks ain't bad but I bet if you found one that was just a Fm tuner it would be cheaper. I wouldn't be able to watch TV from work......even though........that would be nice. I found some on google that were just a FM tuner no tv tuner but they were all in russian. Do these cards use the coax cable connection for the antennae?
i bought a radio tuner a long long time ago and the antenna couldn't even pick up a channel in my room. i think the connector was rca-type and the actual antenna was a wire that was split at the end.
thanks for the responses guys..............i think i'll be buying the leadtek winfast tv2000 expert from newegg............the help is greatly appreciated
