Arcygenical
- Jun 10, 2005
Alright, I'm sure you're all getting sick of the "Does this work with that," and "Which is better," posts... Nonetheless, I really need to start one
I'm kinda confused with the differences between the Black Ice X-Flow and the Black ice Pro 120.2 radiators. I intend to use 2 fans with this at probably 7v. From what I've read the X-Flow is better for quiet fan applications, but I've also seen them used in low flow loops as well. With an x2 at 1.45v and an eVGA 7800 card on the loop (as well as a NB block), which do you think would be my best bet for performance/silence. I might be able to fit a black ice pro 120.3 rad in the top of my case, is that my best bet if it'll fit?
Thanks in advance, I appreciate the help
