NegativeCool
- Oct 28, 2004
Hi everyone. I have the Kingwin AWC-1. If anyone has this same cooler, is the fluid they provide any good? Would I see any benefit from trying automotive radiator fluid? Better still, what should I be using to see nice, low temps? Not suprisingly, the Kingwin website is useless.
I plan on overclocking and the general concensus I've read on here is that I should plan on going to a higher end liquid cooler if I want to see any decent results. Right now, at the stock settings, I run about 46C under full load. I experimented with overclocking a bit and temps were getting very close to 60C. So I reset everything to the stock settings until I did some more research.
This is the first system I've ever built, so I have no reference point.
I used AS5, but since it was my first build, I put it on very sloppily. I didn't get any on the board, it's just all over the CPU. Would there be any benefit from cleaning it up and reapplying it? I've read a few tricks on this site so if I do put it on again, I know the right way to do it. Also, is there any trick to cleaning this stuff up?
Thanks in advance...
