SultanGris
- May 14, 2006
Pretty sure this is a vid card issue, been out of the computer game for a while and shit changes so fast its hard to keep up, used to know everything back in the windows95 days, now i can hardly turn the damn things on, haha!
anyway, i got a monitor on a dvi cable and a lcd tv on the hdmi port of this card, actually the hdmi plugs into my audio receiver and then my tv from there. if i have the receiver on for any reason, even if not routing pc input to the tv say for example using the ps4 or bluray player instead the audio will not work in my computer room, the hdmi takes default even if the speakers are on in the computer room, connected via standard audio headphone jack plug. If the receiver is off they work, if receiver is on they dont.
Maybe a separate issue but also the damn video input flickers sometimes and the tv goes dark for a few seconds and loses audio before it comes back and if i have the tv on and the computer monitor off and then turn the monitor on it will be dark with no video displayed until i go to the settings using the tv screen and change it from duplicate display to extend and then back to duplicate. or the same if the computer monitor is on first, then the tv is blank until i complete this process.
back in the day using these settings with other vid cards they would both work no matter what was on first and i didnt have to do this goofy settings dance, course there was no HDMI plug on the vid card back then, but even with vga and dvi it worked. WTF am i missing? Why wont this FRICKING FRACKING POS just work correctly all the time? getting on my damn nerves for sure. I swear it used to work more consistently before I went on vacation for a few months and powered it off. Is there a bios setting that would affect this that perhaps got reset to default over the long no power state?
thanks for any help
thanks for any help
