Charlie Hustle
- Sep 14, 2006
I upgraded to vista ultimate last night. Everything went well beside my graphic card seem to have an incompatibility issue. This is the card which host my secondary display, so its not a major issue, but i want it fixed.
This is what i get when the desktop opens:
Under device manager it tells me that there is a compatibility issue with the vga driver and the software (error code 43).
I have uninstalled the driver and reinstalled the driver for vista 32 bit but i still get the same error message. Even with the windows update it tries to install the correct driver, but i still get that incompatibility message.
What can i do? Or should i go ahead and box that card and send it back in???
Mind you i upgraded from xp MCE, everything went fine beside this, and yes i did use the driver for vista after i saw the initial problem but still no luck..
Also my specs:
Hp pavilion a1320n
pentium d 820 proc. 2.8ghz
2.5gb ram
OS currently running is vista ultimate..
Also my specs:
Hp pavilion a1320n
2.5gb ram
