Im looking at moving my systems into a single rack configuration. I have a smaller (smaller than standard surfboard) cable modem and dir-655 that I was hoping to find some type of server bracket for, 1u preferred, 2u if necessary.
It will probably be both easier and cheaper to just get a rack shelf (which you can put more than just these two items on) as opposed to getting custom mounting brackets/faceplates.)
cj3waker, probably your cheapest 'server case' would be a mid tower pc you already own in a pair of these Gruber rails for around $25 US:
Red Squirrel, You don't specifically need a rack mount switch to clean that up. Just install a finger duct between the switch and patch panel and hide the wires inside.
And actually, in your set up, I'd drop everything down a little and put another finger duct above the patch panel too and put that bottom most equipment above. It'd look a lot more tidy.
Yeah I've been trying to find a place that sells those. I found automationdirect.com, though the shipping is going to cost an arm and a leg. I also want vertical ducts. I plan to redo the whole rack at some point. I still want a rack mount switch so I can just do patch panel port 1 to port 1 of the switch, 2 to 2 etc... The last ports of the switch would be for the servers and stuff.
