Ok I need some sage advice from you guys.
Current (dead) system is....
A7N8X dlx rev2.0
Mobile +2500 (@2.7ghz on water)
Radeon 9800pro
1gb HyperX PC3500.
I was just surfing the net not doing anything particularly stressful to the computer, and it switched off for no apparent reason. Odd i thought, and went to restart. Pressed the power button, hard disks, fans and cd drives all power up, but thats it. No post, no beep, Nothing,
This is the point where you get a sinking feeling in the pit of your belly. So i had to take it apart and test each bit. Cpu is fine, tested in another computer, 9800 pro likewise, memory i couldn't test, but 2 sticks dieing at the same time seems unlikly. If I turn on with nothing connected to the board but for a CPU, memory and VGA, i get nothing (except the green LED on the board is on), If i remove one of the 3 parts from the board, like the cpu, i get a voice error telling me there is no CPU, or memory or vga, depending on what i remove. Put back all 3 and i get nothng, it doen't even intialise the graphics, the monitor gets no signal at all.
Anyway, having done all i can do to resurrect the board (cleared CMOS too, which did work, because i had disabled voice post in bios origianlly), I am now looking for an equvilant board to my A7N8X dlx. If anybody has more ideas on how to resurrect this board i would be most grateful (i have read the sticky)
Doing some research i have come to the conclusion that the NF7-s rev 2.0 (NOT NF7-S2!) is the board i'm looking for but if therte are any other boards worth considering i would like to hear about them, ideally with the same features as my current dead board. Gotta have sounstorm too, cant do without that.
Thanks for your time.
Nate
A7N8X dlx rev2.0
Radeon 9800pro
1gb HyperX PC3500.
Nate
