nekrosoft13
- Jan 4, 2005
Anyone have seen a quiet FlexATX PSU?
i'm surprised no one made a fanless flexATX PSU yet, those PSU are about the size of big PSU brick, I seen some that are 200W and are about the size of FlexATX.
That is a pretty cool PSU. Any idea if you could get a decent 6 pin or 2x 6 pin connector adapted from it?
I've been playing with the idea of designing a swappable cover plate for the FSP 300W PSU that would basically be 15mm higher and have room for either one thin 80mm fan (i.e. Noise blocker). Do you think this would be a worthwhile pursuit iFreilicht?
Stumbled on theis on the Streacom site some weeks ago, a 240W fanless supply in what appears to be approximate flexATX form factor;
http://www.streacom.com/products/zf240-fanless-240w-zeroflex-psu/
It'll run you some though
http://www.quietpcusa.com/-Streacom-ST-ZF240-ZeroFlex-240W-Passive-PSU-P1093.aspx
They should make it wider to accommodate 120mm fan on the top instead of loud little fan on the rear. It'll be similar to a wide graphics card with blower design.
That's quite cool, but of course it only works with some streacom cases. Still, if you're going for a passive build, that's one easy way to get it small. I wonder if there is a way to actively cool this to get the 450W they claim it would have if it wasn't a passive unit.
I think that's only true for the purposes of mounting holes/L-bracket to their case heatsink. If you remove the L-bracket and put on some heatsinking or using flat heatpipes along those edges combined with decent case cooling could probably get the job done. The Streacoms are basically passive case cooling. None of this would be cheap of course. (There's a build here where someone used this stuff in a really small case)
http://www.thermotekusa.com/tm_phaseplane.php
any 40mm fan cooling a PSU is going to make a load of noise no matter what you try. :/
