Quick ZFS Question - Writing
ldoodle
Hiya,
I have 6 mirrors in my data pool made up of 7200RPM 2t drives, with each disk in each mirror split across 2 controllers.
When monitoring 'zpool iostat -v poolname 2' during an intensive write (1.3t from a USB drive connected to a PC, copying over the 1 gig LAN), 5 of the iterations would be zeroed out (all columns at zero), but the 6th one would be like ~150MB write, then back to 5 zeroed out.
Windows is reporting the write speed as 25MB/s. This seems slow to me but I guess it's the USB 2 interface slowing it down (which maxes out a 480Mb/s)
So just wondering how ZFS actually 'commits' data to disk, and if what I am seeing is correct. 'iostat -exmn' shows no errors.
Sounds about right,
You haven't told us your system specs, but from a USB drive over LAN to system with ZFS 20mb is pretty good
USB is 480 mega BITS /s so equal to about 30 mega BYTES a sec thruput MAX;)
Are you viewing 25MB/s in taskmgr.exe? That number is less accurate than if you were to set up a perfmon configured for your NIC.
Sounds about right,
Specs are Quad Core Opteron, 8GB ECC RAM, LSI 3081E-R (1068E controller)
I know USB is 480 mega bits, which is why I put a small b (Mb rather than MB) ;)
That looks perfectly normal. The USB can only read ~30mB/sec, and because ZFS is copying and it's not a sync write, it just keeps the data in ram until it wants to flush it all to disk in one big write. Everything is fine..
