The mobo in my whs box has 8 sata ports, 4 standard and the other 4 using a software raid controller (Silicon Image Sil3114r5), which I'm now looking to make use of as i've maxed out the first 4. Finally installing the driver for these ports this is my forst foray into raid. Using the software it looks like the easiest thing to do would be to create an individual raid group using jbod for each drive I'd connect to these ports and let WHS do its thing. Couple of questions...
1. Any disks that were connected to the Silicon controller using the jbod method - if they were taken out and connected to a standard sata port, would the data on it be readable?
2. Is it possible to get these Silicon Image ports to function as simple sata ports doing away with the raid manager software, so any drives connected would appear directly to the OS.
3. Assuming the answer to two is 'no', whats some recommended 4-8 port non-raid expander card?
