Quick question
ScratchDrive
hey guys Im attempting my first Case mod..and I need to strip the paint off the case any tips on what I should use to strip it? thanks
If it is the good ol' beige powder coat, you will need to sand it off. If it is just paint, you can use chemical stripper or sand it off. Some say you only have to rought he surface up before painting. However, I prefer to take it down to bare metal and then use primer from there. There are many paint FAQ's around. If you look them up, you might find some other alternatives to what I just posted. Be sure to check them out as you want the best finish possible. No sense going through all that work to paint it if you are going to do it half @ssed.
Good luck with the mod and shoot us some pics when you get done!
