Quick Question Regarding Integrated Card
hAppy
Hey guys, I have another small easy question. I just got a new sound card in, an Audigy 2 Value, my question is do I need to disable my integrated stock sound card for any reason at all? If so how would I go about doing so? Hope to hear a response soon, thanks!
Depending on make/model and age of computer you will need to go into your BIOS (accessable by hitting a key, usually DEL or F1 before your PC boots up) and look for your integrated autio (might be called AC 97) and disable it.
Yeah AC97' that's it! Will it make a difference in performance / quality? I just figured I want the most of my sound card. Thanks for the info.
Well a nice sound card is always a step up from integrated sound, also having lots of new features and surroundsound support is a definate plus.
I meant would disabling the integrated boost the performance on the sound card? Or would it be pointless? Thanks for your help.
Nope.
But what is the point of leaving the onboard solution active if you are not going to use it?
about the only time you'd leave both active is if you're having problems with the microphone input on your pci soundcard.
Otherwise, as the last five posters have said: disable it
I have never been into the BIOS by myself before, and so today I tried to find the integrated audio, couldn't find it, I found a bunch of other misc things, but didn't find it. A little help please :p , thanks for your advice btw!
what motherboard do you have?
Otherwise look for some submenu that lists "audio" or "ac97" or similar.
Push the Del key to enter the bios configuration utility on system startup.
Use the page up page down keys to navigate to the integrated peripherals section and press the enter key.
Highlight the VIA on chip PCI deceive sub menu and press the enter key.
Select the VIA-3058 AC audio device option and change the setting to disabled.
Use the Esc key to exit the submenu.... then hit it again to exit the integrated peripherals section.
Use the F10 key to save the changes.
Then use the enter key to exit the BIOS configuration utility.
Your onboard audio should now be disabled.
OMG the scariest thing just happened to me, I'm still shakened. :eek:
Anyways, I followed your instructions Mister X, after I did all that, saved and all, the computer took me into a window, the "continue in safe mode, safe mode w/ networking, continue normal, etc", after I chose any option, the computer just stopped at that point, just went into a black screen and the computer was still on, nothing but black screen. I was so scared I called my friend told him what happened and he told me to reset the BIOS to default settings.
Well I'm too scared to ever go into the BIOS again. I am 99% sure I did it correctly, when I restarted the computer again, I went to the BIOS and tried to enable the sound again, that didn't work either. What happened there? Anyways thanks for your help. Say if I just left the integrated sound enabled, would it use up computer resources or anything of that sort, or is there some other reason to disable it? Thanks again.
Just let it boot........Windows is looking for a device that is no longer there and it will take a few minutes longer for it to boot up.
Once you get into windows remove the drivers and you should be all set.
Hmm I went to the shower for about 15 mins or so while I waited, when I came back I began to worry. hehe alright glad to know it wasn't a big deal. Thanks man!
Sometimes things don't always work the way they should with Windows..... if worse comes to worse you can always pop in your Windows CD and repair the installation to sort it out. ;)
Nothing to get excited about.
