- Jul 8, 2005
Just wondering how to tell if your CPU is a bottleneck. I'm running a E2180 with a measly 1mb cache @ 3ghz and think it may be bottlenecking my GTX 260 oc'd. My CPU never really maxes out to 90-100% usage, but I think the cache is really hurting performance. Reviews with Quad cores overclocked to 3.0-3.2ghz and dual cores overclocked to 3.0-4.0ghz are getting higher benchmarks then me(especially minimum fps) and I believe this may be do to the cache size of the dual/quad cores being 4-6mb.
I remember reading that by changing the resolution you should be able to tell if your cpu is holding you back, but forgot the details. I don't really gain any fps going from 1920x1200(my gaming res) to 1680x1050 or even 1440x900 in crysis. I guess I need to test COH and WiC too...
What do you think?
What do you think?
