I'm going to have a new monitor setup soon, PLP style. This is how i want to set it up.
22" 60Hz 1080p Portrait DP | 24" 120Hz 1080p Lanscape Dual Link DVI | 22" 60Hz 1080p Portrait DP
Now regarding the connections, if i were to hook them up to an AMD 6970 (or 7000 series card if they're out in the next couple of months) the 120Hz screen will be connected via Dual Link DVI obviously, but the portrait monitors both via DP or one via DP and the other via the remaining DVI connection. I've never worked with DP before really and i'm not sure if i'll need active DP adapters or not? The setup will be extended desktop across all 3 but gaming on just the 24" 120hz screen. Will passive DP adapters allow 1080p @ 60hz for desktop use only? For example http://www.overclockers.co.uk/showproduct.php?prodid=CB-047-OK&groupid=1929&catid=1756&subcat=
Edit:
New plan. Fuck Eyefinity.
I can get a good deal on an Asus GTX580 Matrix so i'll go the nVidia route. Along with it i'll use the Asus GT 440 SILENT for the side monitors in portrait. So it now comes down to the question on running 60Hz | 120Hz | 60Hz . Remember the 120Hz will be the primary monitor and the only one i plan to use when gaming.
I just want the 120Hz screen in the middle set as the main/primary monitor for desktop and gaming at 120hz and the side 60hz screens just as additional monitors for extended desktop for Winamp, web browsing and spreadsheets etc i don't want to use them for gaming at all but don't want to have to disable them to take advantage of the 120Hz on the middle screen. The side monitors will be running off of the GT440 leaving the GTX580 to power only the 120Hz screen (so that there are no issues with the GTX580 idling at 2d clock speeds on the desktop basically).
Edit:
