How the hell do I remove these standoffs? The screws on top of them, holding the motherboard to the metal plate, will not unscrew. This is kind of urgent too, I'm in the process of transferring the motherboard to a new case.
Are you talking about those copper standoffs? I must assume that you didn't install your mobo into this case, so it must be a somewhat proprietary case. From looking at where the standoffs get locked onto the case, it was designed so you can just push your mobo to one side until the standoffs are dislodged and take your mobo out that way. If this is correct, then I don't now how you will get those standoffs off your mobo, though, because a new case may not have those kind of mounting holes.
