Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I'm looking to raise the maximum override frequency for specific resolutions. For instance, my monitor will allow me to run at 75hz at 1600x1200, but I can only override it to 70hz via ATITool.
You can manually type in a value in the selection box, however, I find that it doesn't apply correctly. For example, my monitor supports 1152x864 @ 100Hz, but ATiTools gives me up to 85 max. If I type in 100 and apply, when I set the res to 1152 the rate will stay at whatever it was previously.
Most annoying, so I'd be interested in a solution for this too (other than just using Powerstrip, which works great for any resolution/refresh-rate).
