Not sure if this should go into the worklogs sub-forum, but it it should a mod will move it
I'm building a mini-farm for the folding team and saved this lottery ticket dispenser for it.
The trays are just the right size to hold a bare MATX board. I've cut two 120mm holes with a dremel for fan intakes already. Now I'd like to figure out how to mount the boards. As I see it I have a couple options, but I'm worried about the static buildup that plastic can have. Here are the options and tell me what you think about my static fears:
1.) I use brass standoffs
2.) Skip the standoffs and use a screw and nut to mount directly onto the plastic
3.) Don't mount, just stick the foam sheet from the MB box underneath
and of course pics for reference:
