Irishllama
- Nov 29, 2004
I plan on hosting small lan parties (15) ppl or less... But i want to use Fiber... What switch Do you recomend? also what PCI card do you recomend for my computer?
IceWind said:Now, if you were doing 1,500 person party, then we'd talk.
tiebird321 said:fibre and copper are the same speed...
mostly
the speed of light does verry depending upon the media it is passing trough
but the difference in copper vs glass fibre is tiny even over longer distances
the reason fibre is used is it is not affected by electromagnetic interfearence, it does not degrade or oxadize
and when your talking about doing multi KM distances the wire is cheaper than copper
admitedly my house is wired with fibre....
but that was because i gutted it and started over and i was thinking about badwith 20years down the road
but its also wired with copper and except for the core switch and the server... everything is wired with copper
(yes my house has a 3com core switch.... yay bankrupcy auctions)
any of the big vendors make base 100 and base gigabit fibre switches and routers
fibre switches generaly start at $50 per port or MORE and the adapters for the computers are $300-400 and up
BobSutan said:
