Hi all, I plan on buying this: http://www.svc.com/zanoco.html for a quiet, SFF machine I will be building soon. It says it is incompatible with Northbridges that have built in graphics. But, asyou can see here: http://www.newegg.com/Product/Showi...Force+6100+Micro+ATX+AMD+Motherboard+-+Retail the Northbridge and Southbridge coolers are total crap in comparison to the Zalman. Will the Zalman work? Also, the Northbridge and Southbridge look to be almost exactly the same size and hole pattern-- could I use 2 of the Zalmans, one on the Northbridge and the other on the Southbridge? Or is there a problem that a noob like me does not know about?
Any help is appreciated.
