are you going to us the ms vga cable to connect your 360 to your widescreen? i'm using the cable to hook up my 360 to my lcd monitor and the sound inputs of the cable are plugged into my fatality's line in, which outputs to my z2300s. i used to use z640s and i had no problems getting 5.1 sound this way.
