Each motherboard has a specific socket that will match a cpu. To find which socket it is you can look online at the specifications or if you are at the store it should be somewhere on the box. Common sockets are "Socket A" for amd or "Socket 478" for intel. There are several other newer sockets to match the new cpus. The cpu will need to match the socket.
Other items you need, to have an operating computer are ram, video card and a power supply. But you will also want sound and network cards, floppy drive, hard drive, optical drives. All of it is either plugged directly into it or attached by a cable to the motherboard. Some motherboards will have some of these components integrated saving you from having to buy the add-in cards.
Thats a quick and dirty explanation with not much details, hopefully that will get you started!
Also, aside from the socket, you must make sure that the motherboard supports the CPU's FSB speed. Check on the chipset version, the motherboard's website, or the box whether it supports your fsb.
Typical Socket A fsb speeds for AMD are:
133/166/200
you need to make sure the motherboard supports your FSB speed.
