question about watercooling
Davmx
ok, Im using SP-94 and I had to remove the plastic cpu retentation thing. I was thinking of getting a watercooling kit since im a noob at building my own.
So which water kit doesnt make use of then plastic retention thingy? thanks
I actually can't think of any blocks off of the top of my head that use that plastic retention thing. But, I also don't know about a lot of the pre-assembled kits out there like koolance, etc. Those might.
You shouldn't need that for any Danger Den, Swiftech, DTek, or any other high end block really.
this is what i'm running right now:
5:4
2.8e-3.3ghz stock hsf stock volts
ai7 with gameacceleration-speed racer
ocz pc4000[default is 2.5.4.4.7 i think] at 2.3.3.6 with 2.6 volts
all of this runs STABLE, but i do get an error on prime95 after a few minutes.
Will better timings , 1:1 and a 3.2hz speed be better than what i'm doing right now?
any help is appreciated.
