Question about Videocard Overclocking..
Isaacav2
When I use CoolBitz for my 6800GT... I can overclock my 3D and 2D independantly. Does it make sence to have the settings differant from 3D and 2D? Or should I keep them the same overclocked rate?
you dont want to overclock your 2D really, it will cause the card to burn out a lot quicker as it never gets a break from being OC'ed and also raises the temps of your entire case.
Personally don't think it really does anything... Why??? Because your 3d card isn't really working in 2D... My temps stay the same if I overclock or not in 2D of course.... 3D is another story...
Either way if you option to turn down the clocks on 2D... Why not? It couldn't hurt... Maybe save 2 watts or on your electricity bill.
http://techreport.com/reviews/2004q4/radeon-x800xl/index.x?pg=12
Between a ultra and 6800gt in idle mode you save 2 watts of power...
dont do it its pointless imo, u wont get ANY performance gain in 2d mode, just overclock 3d and leave 2d alone, as it does put more of a strain on the card (and why would u wanna make it get hotter when it does nothing), and more heat= less lifetime, food for thought
Main reason why I ask is because my new RMAed BFG680GT Comes overclocked @370mhz for both 2d and 3d. When I play CS:S with HDR, my card gets up to 100c during load, is that normal? Is there room for more oc? up to 85 with normal CS:S.
It won't make a difference in 2D... Because your chip isn't doing any work in 2D...
For instance my x850xt sits @ 50C in desktop brownsing the net watch movies only using 5% fan... When I fire up a game... It goes 80C using 50-60% fan... I suggest you go get a aftermarket heatsink... 100C is hot... Boiling point..
u neeeed better ventilation. whoa! 100 isnt unheard of, it just doesnt have to be.
It normally doesn't float around 100, more like 80-90ish, should I still be worried?
I have like 4 fans in my case ....
Like I said, I've seen it that high but it shouldn't be that hot. So, consider better ventilation or placing a fan either directly on the the VC or change the cooler itself. Maybe it just needs a nice coat of AS5 to bring the temps down.
Nvidia cards tend to be cooler than ATI power hogs. Mine will reach in the 80s.
I have Dynex Silver Thermal Compound .... Will that be worth trying to put on my Newly RMAed Videocard? Like I said I float around 78-100, never 102. With HDR that is, its about 8 degrees cooler without it.
Thanks
