Question About Slk948u
v8_h8r
First will this heatsink hold a 80mm fan or just a 92mm and 120mm, thermalright's site doesnt tell u jack. second has ne one else found a better cooling solution other than water cooling for the same price as the SLK948U. Keep in mind if a 80mm Vantec Tornado will fit on there i already have that fan. But if not include the price of the heatsink plus a 92-120mm fan. All input would be appreciated. Also Pure copper heatsinks only.
Thnx
There is nothing better. And yes you can install a 80mm fan on it. But would be better with a 92mm...Also I dont think the 948u supports 120mm fans. I thought that was only on the SP120 whatever that one is called...
ok that is what i was wanting to know. as i mentioned b4 thermalrights site doesnt tell u n e thing
