Question About Rocketfish Case
Lt.Col.Dehler
I think today i am going to BB to pick one of these up. My question is, is it possible to flip the motherboard tray and back panel so everything is upsidedown? because i have heard that some psu's cpu power connector isnt long enough.
ok, thanks. lets just hope my 24pin and 4 pin connectors are long enough because i really like this case.
you probably will be able to get away with the 24pin connector, but might need a 4 pin extension depending on how you're able to snake the 4 pin connector
What kind of PSU do you have? I've got a Corsair VX550 and I had a good 4-5 inches to spare in my Rocketfish.
the average oem minitower psu length isn't going to be enough. i bought this GT5636E http://support.gateway.com/s/PC/R/1014825R/1014825Rnv.shtml and the delta 400w cord won't reach in this lifetime. especially with the motherboard's connector all the way up in the right corner. i am thinking now that i may swap my p150 innards c2d, x1950, nec 3520, but i want to keep this labelflash software with this optiarc drive that came with the unit...
Performance-PCS has several extension cords for the 24-pin and 4/8-pin ATX power cables. They come pre-sleeved and you get to choose your choice of color sleeving.
Corsair HX520 power supply cable reached with no problem on my Gigabyte DS3L with some length to spare. The 4 pin connector is in the top left corner of the board which is the worst case scenario.
i just finished putting everything in got it for $50 at BB. love it, its quiet. and everything reached. Cable management isnt that great but oh well. but ill make some changes.
