Question about PCI-E
dogbyte_13
If the motherboard has 1 PCI-E 16x and 1 PCI-E 1x can both be used at the same time and if so is there a performance degradation?
Yes they can be used at the same time. No, there should not be any performance degradation.
Some boards have two 16x slots that switch to 8x/8x electrical if there are cards in both, (Sometimes 16x/4x, or other odd things like that too) but I've never heard of similar schemes with 1x slots..
Depending on the board some of the pci-e slots get turned off or reduced speeds when certain other slots are used.
For example alot of gigabyte boards have this setup on the second 16x slot:
1 x PCI Express x16 slot, running at x4 (PCIEX4)
* The PCIe x1 slots share bandwidth with the PCIEX4 slot. When one of the PCIe x1 slots is populated, the PCIEX4 slot will operate at up to x1 mode.
AFAIK, it's all based on the amount of PCI-E lanes the board has. Some have many more than others. They are divided up between connectors based on x16/x4/x1, etc., but that's only guaranteed if one device is plugged in. As munkle pointed out, if you start filling multiple slots, the motherboard may reduce bandwidth to each slot to balance it out. The truth is though as long as you have 8x, for GPU's you won't notice a difference in performance in most cases. SSD's based on PCI-E lanes can saturate a 1x 2.0 link though.
Also remember that the 16x slot is not the same as an x1 slot, if you're thinking about putting another video card in or something.
You can put a video card in a x1, x4, x8, or x16 slot, the slot just needs to be openended or you can cut the back of the connector open so it fits. The card will work fine just at reduced performance.
My old a8n-e had an open ended x4 slot that was x1 electrically and it worked fine with video cards.
I definitely did not know that. Though cutting anything on the motherboard open sounds like a horrible idea and would probably void any warranty.
