Question about DFI's PCI-E Lanes
Jellox
Do both lanes offer the same performance? I might get a XP-120 but it will block the top PCI-E lane. Will I notice a difference if I move the card to the bottom slot?
From what I understand when running in regular mode the top slot is 16x and the bottom is 1x. When you go to SLI mode the top and bottom are both 8x. So i assume you cut put the board in SLI mode and run it in the bottom slot. I doubt that running at 8x instead of 16x would make any diffrence
